Number of client licenses used
  • Number of client licenses used
  • DavidChild
    DavidChild
  • RobertAndriolo
    RobertAndriolo
  • PeterEdvik
    PeterEdvik
  • PeterLarsen
    PeterLarsen
Janeway PeterEdvik Janeway
‎2020-03-18 02:56 AM
Last Updated: Picard RobertAndriolo Picard ‎2022-01-23 09:20 PM
How many client licenses are currently used?
Which host is using the licenses?
Licensing
Information about license usage is needed to ensure licensing is adequate.
Information about current license usage can be found in the FlexNet License Administrator found on the server where the Building Operation License Administrator is installed. FlexNet License Administrator has a web interface accessed through a web browser. The address is the server address and port 8888.
If on the license server go to:
http://localhost:8888
If on a remote machine to access the FlexNet License Administrator go to:
http://[license server ip address]:8888
Once accessing the FlexNet License Administrator, switch to the Concurrent licenses view by clicking on the Concurrent icon.
Scroll down to the client.station in the Feature column.
The column In Use (Available) shows the number of client licenses used. (The number of client licenses available is displayed in parentheses).
(Click on Hosts to display a list of hosts taking client licenses.)
Tags (4)
  • HernanUruena25
  • PeterEdvik20
  • PeterLarsen22
  • PeterLarsen24
100% helpful (5/5)
