Notification report can't be written to file with Alarm "System alarm: File access error: sharing violation:"
  • Notification report can't be written to file with Alarm "System alarm: File access error: sharing violation:"
  • Mahmoud_Sayed
    Mahmoud_Sayed
  • RandyDavis
    RandyDavis
Kirk Mahmoud_Sayed Kirk
‎2022-06-07 09:40 AM
on ‎2022-06-07 09:40 AM
EBO can't overwrite notification report file.
"System alarm: File access error: sharing violation:""System alarm: File access error: sharing violation:"
  • Building Operation Enterprise Central
  • Building Operation Workstation
Notification file is used by another program and "Uniqueness" paramter is set to "None" so EBO can't write on it, ex, Microsoft Excel opens the notification report.
  1. Make sure that notification report is not used be another program, ex. Microsoft Word or Excel.
  2. If the program locking the notification file is not known, Windows Resource monitor can be used to know which process is locking the file, as below:
    1. Press Windows key+R to open "Run" dialog box.
    3. In Resource Monitor "CPU" tab, expand "Associated Handels"
    4. In "Search Handels" box, write the notification file name.
    5. In "Image" tab, note the process name.
    6. To end the process which is locking the file, Right-click on the process and then click on “End Process”.resource monitor KB.jpg
  3. It is also possible to append or prepend a timestamp to the file name, so EBO can generate a new file each time.Notification Report File timestamp.png
  • MahmoudSayed22
