Not possible to specify the Lon device subnet/node in EcoStruxure 1.6.1 and earlier
  • Not possible to specify the Lon device subnet/node in EcoStruxure 1.6.1 and earlier
  • Jonas_Brissman
    Jonas_Brissman
‎2018-09-06 09:07 AM
In for example TAC Vista it was possible to specify the subnet/node address when adding a Lon device, is it possible to do this in any way in StruxureWare Building Operation(SBO)?
StruxureWare Building Operation version 1.6.1 and earlier
In version 1.6.1, this is not possible.
The plan is to add this functionality to SBO version 1.7.
  • 17636
