Not possible to filter alarms on priority using comma.
  • Not possible to filter alarms on priority using comma.
  • Jonas_Brissman
    Jonas_Brissman
‎2018-09-06 02:25 PM
If alarms with priority 1 and 4 to 10 should be shown in the alarm window, it has been possible in earlier versions (before Vista 5.1.4) to write "1,4-10" in the filter for alarm priorities. Today it is not possible to use the comma. An error message saying "Invalid input, check values and syntax" will appear when closing the filter.
Vista Workstation 5.1.4
It is only the user interface which will not allow a comma.
Use the raw dialog for filtering the alarm window instead.
  1. Hold down Ctrl+Shift and click on the filter button
  2. Change APPRIO.
Fixed in version 5.1.5.
  • 4000
