No link LED on a Desktop's and Laptop's Network Interface Card (NIC).
  • No link LED on a Desktop's and Laptop's Network Interface Card (NIC).
  • CraigEl
    CraigEl
  • Julio_Cortes
    Julio_Cortes
‎2018-09-06 01:05 PM
Last Updated: Administrator CraigEl Administrator ‎2025-10-21 10:09 PM
The network interface card (NIC) on a desktop or laptop shows no link LED activity, indicating no network connection.
Andover Continuum, Satchwell BAS & Sigma, Satchwell MicroNet, TAC IA Series, TAC INET, TAC Vista
  • Windows Operating System
  • Devices with built-in or external NICs (Network Interface Cards)
The NIC may have power management features enabled. These features can automatically disable the NIC under the following conditions:
  • No network activity is detected
  • Battery power is low
  • Battery connection is intermittent
This behavior is designed to conserve power but can result in the NIC appearing inactive or disconnected.
To resolve this issue, disable the NIC's power management settings:
  1. Open Device Manager.
  2. Expand the Network Adapters section.
  3. Right-click your NIC and select Properties.
  4. Go to the Power Management tab.
  5. Uncheck the box that says “Allow the computer to turn off this device to save power.”
  6. Click OK to apply the changes.
Additional Notes
  • This issue is commonly observed on laptops running on battery power.
  • Disabling power management may slightly reduce battery life but ensures consistent network connectivity.
Labels (6)
  • Satchwell BAS & Sigma
  • Satchwell MicroNet
  • TAC IA Series
  • TAC INET
Tags (2)
  • 6559
  • CraigEllis25
