No events in the Report Server SQL database and events not updating
Select a Country
  • No events in the Report Server SQL database and events not updating
‎2018-09-11 01:06 PM
Last Updated: ContentModerator Explorer ‎2025-09-01 03:36 AM
No events are transferred to the Report Server SQL database. Trend logs are transferred just fine.
In the report agent log you can see this message "Sequence contains no elements"
Report Server
Warning
The Enterprise Server has been renamed before the Report Server has been installed or before the Report Server Agent has started collecting data.
This issue will be fixed in a future version, but until that, do the following to correct the issue:
The fix is split into two sections. First, a section working with the "event.db" file from the SBO database, and second a section working with the "StruxureWareReportsDB" from SQL Management Studio.
"event.db" from the SBO database
  1. Download http://www.sqliteexpert.com/download.html (Just take the personal one)
  2. Stop the Enterprise Server
  3. Copy the "event.db" file to a safe location
  4. Attach the "event.db" file to "SQLite Expert Studio"
  5. Get the first event from the event.db using the following query in the "SQL" tab:
    SELECT SEQNO,TimeStamp,EventGUID,SourceServer
    FROM t_7E_2FSystem_2FEvents_2FEventLog_2FEventRecords
    ORDER BY SeqNo
    LIMIT 1;
  6. Convert the TimeStamp with this "SBO TimeStamp Converter" tool
"StruxureWareReportsDB" using SQL Management Studio
  1. Write the following SQL query in SQL Management Studio, using the converted time stamp, and the Guid you found previously.
    INSERT INTO StruxureWareReportsDB.dbo.tbEvents
    (DateTimeStamp,SeqNo,OriginalSeqNo,Guid) VALUES
    ('2014-04-17 08:35:23.857','1','1', '380d1c4c-c60b-11e3-8ecb-b8ac6f81243c')
  2. Start the Enterprise Server again
  3. Restart the Report Agent and let it run for a while.
SBO TimeStamp Converter.zip
Tags (5)
  • 17527
  • 26975
  • defect
  • RobertAndriolo19
  • RobertAndriolo21
67% helpful (2/3)
