Niagara R2 MNB Controller Learn Failure with MN-Sx Sensor and BACnet Jar 527i
  • Niagara R2 MNB Controller Learn Failure with MN-Sx Sensor and BACnet Jar 527i
  • CraigEl
    CraigEl
  • sesa119747
    sesa119747
  • Kim_Baze
    Kim_Baze
‎2018-09-06 02:36 PM
Last Updated: Administrator CraigEl Administrator ‎2025-12-14 09:00 PM
When learning an MNB controller into a Niagara R2 UNC station that includes an MN-Sx sensor, a read failure occurs and multiple WARNING messages appear in the Standard Output Window.
These errors did not occur with BACnet jar files prior to version 527i.
TAC IA Series
  • MNB controller
  • Niagara R2 UNC station
  • MN-Sx sensor
  • BACnet jar file (527i)
A change introduced in BACnet jar file 527i causes these warnings:
  • The read failure occurs because the S_LK_Display1 object has no description property.
  • Subsequent warnings appear because Niagara R2 does not support certain files listed during upload.
    These conditions existed in previous BACnet jars but were not reported until version 527i.
  • These messages are legitimate and expected behavior with BACnet jar file 527i and later.
  • No corrective action is required; the warnings do not affect system functionality.
  • TAC IA Series
Tags (2)
  • 3499
  • CraigEllis25
