Niagara G3 (AX) Station Save and Backup Station
  • Niagara G3 (AX) Station Save and Backup Station
  • RandyDavis
    RandyDavis
  • sesa119747
    sesa119747
  • sesa116871
    sesa116871
‎2018-09-06 02:34 PM
Last Updated: Guinan RandyDavis Guinan ‎2023-02-14 06:05 AM
In a Niagara G3 station, what is the difference between a Station Save and Backup Station?
TAC IA Series
  • Niagara G3 (AX) Jace/ENC
  • Niagara G3 (AX) Enterprise Server (ENS)
Help determine which feature (Station Save and Backup Station) meet the requirement.
A Station Save only saves the config.bog file to the local device (if an ENC, it will save the file on the ENC; if an ENS, it will save it on the ENS computer).
The Backup Station function performs a complete backup of the connected ENC or ENS station, saved as a dist file on the Workbench computer. The backup dist contains the entire station folder plus the specific NRE config used by that ENC or ENS platform, including license(s) and certificate(s).
The dist also contains pointers to the appropriate NRE core, Java VM, modules, and OS. If ever needed, you can restore a backup dist using the platform Distribution File Installer view. The backup dist file also contains the TCP/IP configuration of the host when it is backed up. When restoring the backup, the choice to restore these settings, or retain the TCP/IP settings currently in use by the target host is available.
  • TAC IA Series
Tags (2)
  • 3619
  • RandyDavis23
100% helpful (1/1)
