NCP Palm - Using the IR Tool or RS 485 converter to communicate with the controller.
  • NCP Palm - Using the IR Tool or RS 485 converter to communicate with the controller.
  • CraigEl
    CraigEl
‎2018-09-11 06:25 AM
Last Updated: Administrator CraigEl Administrator ‎2025-10-07 03:44 PM
How to use the IR Tool or RS-485 converter to establish communication with a Unifact Pro controller.
Satchwell BAS & Sigma
  • NCP Palm
  • IR Tool
  • RS232 to RS485 Converter
  • Unifact Pro Controller
Need for proper configuration and connection method to communicate with the controller using NCP Palm.
Using the IR Tool:
  1. Connect the IR Tool to both your laptop and the Unifact Pro controller.
  2. Launch the NCP Palm program.
  3. In the program:
    • Select the correct serial communication port.
    • Uncheck the CTS / RTS selection boxes.
    • Click OK.
  4. From the File menu, select Connect.
    • Enter Subnet Address: 0
    • Enter Node Address: 0
    • Click OK
      ✅ You are now connected to the IR Tool.
  5. To connect to the controller:
    • Go to File > Disconnect
    • Then go to File > Connect
    • Enter Subnet Address: 1
    • Enter Node Address: 1
    • Click OK
      ✅ You are now connected to the controller
Using the RS-232/485 Converter:
  • The process is similar to the IR Tool method.
  • Instead of using the IR Tool, connect directly to the controller’s communication terminals via the RS-232/485 converter.
Additional Resources:
📎 NCP Palm Engineering Guide
Labels (2)
  • Field Devices
  • Satchwell BAS & Sigma
Tags (2)
  • 15048
  • CraigEllis25
