Multiple instances of Tacos running in Task Manager
  • Multiple instances of Tacos running in Task Manager
  • David_Kendrick
    David_Kendrick
  • Sacco
    Sacco
‎2018-09-07 01:14 AM
Last Updated: Admiral David_Kendrick Admiral ‎2022-08-09 08:05 AM
TAC Vista
  • TACOS.exe
  • Vista Server
It is possible that Vista Server will try to start multiple/additional instances of Tacos.exe when starting.
Re-register the service. This can be accomplished by executing Tacos.exe with command line switches.
  1. End all Tacos.exe processes.
  2. From the Start Menu "run" command prompt perform the following:
  3. tacos.exe /unregserver
    (to unregister Server)
  4. tacos.exe /regserver
    (to re-register Server)
This should re-register Server. If Server executes as a result of the command, you have most likely entered it incorrectly. Restart Server and observe.
See Registering/Unregistering TAC Vista Server as a Windows service for more information on registering Vista Server as a service.
Tags (2)
  • 2390
  • DavidKendrick22
