More than 1 temperature sensor is required to be wired on Single input - series parallel
  • More than 1 temperature sensor is required to be wired on Single input - series parallel
  • Ramaaly
    Ramaaly
  • DavidChild
    DavidChild
‎2018-09-07 02:03 PM
Last Updated: Lt. Commander Ramaaly Lt. Commander ‎2022-04-04 12:12 PM
There is only 1 input available, but the end-user wants more than 1 sensor to be connected, where the reading will be averaged.
EcoStruxure Building Operation, EcoStruxure Building Expert
  • Building Operation Workstation
  • Building Operation Automation Server
  • SSL SE8000
The wrong sensor type or incorrect wiring might have been used.
4 resistive sensors of the same type are required.
Depending on scenario, 2 sensors may have to be fitted adjacent to each other, or fit 2 sensors into 1 sensor housing to achieve the correct number of zones to be monitored.
For wiring follow the drawing below:
Labels (7)
  • Field Devices
  • Satchwell BAS & Sigma
  • Satchwell MicroNet
  • TAC IA Series
  • TAC INET
Tags (2)
  • 4869
  • RamaAly22
