ModBMS Prevents OPC Client from Writing OPC DA Values to Sigma
  • ModBMS Prevents OPC Client from Writing OPC DA Values to Sigma
  • CraigEl
    CraigEl
‎2018-09-06 02:07 PM
Last Updated: Administrator CraigEl Administrator ‎2025-10-07 10:11 PM
ModBMS does not allow an OPC Client to write OPC DA values to Sigma. However, reading values from ModBMS/Sigma is successful.
Satchwell BAS & Sigma
  • Sigma versions 4.04 and earlier
  • ModBMS
  • OPC Client
ModBMS uses DDE (Dynamic Data Exchange) functions to read and write data to the Sigma server.
In Sigma versions prior to 4.05, the DDE write function was not supported. This limitation was resolved in Sigma version 4.05 and later.
To enable OPC DA write functionality, upgrade Sigma to version 4.05 or later, where the DDE write capability has been implemented.
  • Satchwell BAS & Sigma
Tags (2)
  • 4636
  • CraigEllis25
