Mobile Apps for EcoStruxure Building Operation
  • Mobile Apps for EcoStruxure Building Operation
  • Mahmoud_Sayed
    Mahmoud_Sayed
  • Chris_Asbury
    Chris_Asbury
  • sesa139513
    sesa139513
  • sesa119747
    sesa119747
‎2018-09-11 12:49 AM
Last Updated: Kirk Mahmoud_Sayed Kirk ‎2023-07-30 08:25 AM
Need to use Mobile Apps to access EBO.
  • Building Operation Webstation
  • Building Operation Commission mobile application
  • Building Operation Engage mobile application
What are the mobile apps available to use with EcoStruxure Building Operation sites?
  1. WebStation: WebStation is a web-based user interface for day-to-day operation in an EcoStruxure BMS. WebStation, V2.0 or higer, improves user experience by automatically adapting the user interface to the resolution of the device being used: desktop, laptop, tablet or smartphone, using Windows, Linux, Android or iOS, out-of-the-box using standard web browsers, without the need to install additional applications.  WebStation replaces the obselete Technician Tool app. Refer to: WebStation Overview
  2. Building Commision: EcoStruxure Building Commission mobile application (requires EBO V2 or higher, formerly eCommission) is designed to help airflow balancers, electricians, and technicians carefully and quickly pre-commission and commission SpaceLogic BACnet/IP devices and RP controller expansion modules. The Commission mobile application does not require a license for activation and is available at no cost to the user. It is designed for use with Android, iOS (Apple), and Microsoft Windows 10 and Windows 11 devices, and is available for download from Google Play, Apple App Store, and Microsoft Store. Refer to: Commission Mobile Application
  3. Engage: The Engage mobile application (requires EBO V3.1.2 or higer) enables control of room temperature, fan speed, lights, and blinds/shades directly from a smartphone. A user can manage these settings when the application is connected to the RP-C controller. The Engage mobile application connects easily via BLE (Bluetooth Low Energy) to the RP-C controller. The application is compatible with RP-C (HVAC) and RP controller expansion modules (lights and blinds). The Engage mobile application is free and available for download from Google Play and Apple App Store.
Tags (2)
  • 12222
  • MahmoudSayed23
100% helpful (2/2)
