Microsoft Licensing for SmartStruxure Report Server
  • Microsoft Licensing for SmartStruxure Report Server
  • JohnBoehmer
    JohnBoehmer
‎2018-09-06 09:49 AM
How many SQL client licenses to run SQL if SQL 2008 is used to run Report Server?
When Report Server is installed, is there a connection between SQL and the Enterprise Server.
  • Report Server
  • Licensing
Licenses must be purchased for supporting software (OS, SQL, etc).
Because SQL and Report Server have to be running on the same machine, there is only one sequel user that requires licensing.
There is no connection between the Enterprise Server and SQL when Report Server is installed.
  • 15126
