Menta module names disappear when importing a Menta file.
  • Menta module names disappear when importing a Menta file.
  • Jonas_Brissman
    Jonas_Brissman
‎2018-09-06 10:34 AM
Menta module names disappear when exporting a Xenta from Vista version 5.1.8 and importing it to Vista version 5.1.7
TAC Vista 5.1.7 and 5.1.8
Changes is made in the export/import function in TAC Vista 5.1.8 which will cause problems to import a export file from TAC Vista 5.1.8  in to TAC Vista 5.1.7.
To be sure that the export/import function should work only export and import between Vista systems of the same version.
  • 12796
100% helpful (1/1)
