What is the maximum number of site codes that can be loaded into a Continuum system?
Andover Continuum
AC-1 and AC-1 Plus modules
Network design limitations
There is no limit to the number of site codes that can be loaded in a Continuum system. However, each door can contain a maximum of four (4) site codes. In the case of an AC-1 module, if it loses communication with its associated Netcontroller, it will only allow access from the first two fields.
