Maximum number of Credential Types
  • Maximum number of Credential Types
  • RobertAndriolo
    RobertAndriolo
  • AdamSteele
    AdamSteele
Guinan AdamSteele Guinan
‎2020-02-02 02:18 PM
Third party system can handle up to 14 user credentials. Is there a limit to the number of Credential Types that can be created, and used, in Security Expert?
EcoStruxure Security Expert
  • Security Expert
  • Custom Card Formats
There are no noted limits in current documentation on how many Credential Types can be used.
There is no known maximum to the number of Credential Types that can be created in Security Expert and applied to a User object, however;
  • Limited testing has confirmed that two hundred (200) Credential Types were able to be created, added to a User, and then successfully downloaded to the Controller.
  • This is a rough guide only. Results will vary depending on how many Users are being downloaded to each Controller and the number of Credentials each of those Users has applied.
  • EcoStruxure Security Expert
Tags (3)
  • AdamSteele20
  • AdamSteele23
  • AdamSteele24
