Making Changes to I/O Server
  • Making Changes to I/O Server
  • Roger_Bently
    Roger_Bently
‎2018-09-06 12:32 PM
Making changes to I/O Server with out logging into I/Net or I/Net Configuration
All versions of I/Net Seven prior to 2.40
Without login on to I/Net or the Configuration Editor, changes can be made to the system and accepted.
When I/Net is launched it authenticates the user thus allowing the changes, however, if the user does not log on, the buttons that require this authentication are all grayed out., So it may look like changes can be made but notice that the OK button does not become available, so no changes will be saved in version 2.40 and above.
  • TAC INET
  • 7585
