'Make Active' button grayed out in I/NET Configuration Profiles editor
  • 'Make Active' button grayed out in I/NET Configuration Profiles editor
  • RobertAndriolo
    RobertAndriolo
  • Derrick_Ratliff
    Derrick_Ratliff
‎2018-09-06 01:09 PM
Can not change my active I/NET (configuration) profile.
I/NET Seven 2.40 and above
The INetIoSrv.exe application must be shutdown before you can make any other configuration profile active.  This change was made in I/NET Seven version 2.40 and above.
To enable this button the INetIoSrv.exe (IO Server) application must be shutdown.
  • Ensure I/NET, AMT and the IO Server are not running
  • Start 'I/NET Configuration Profiles' editor
  • Select desired profile and select Make Active
If I/NET has every been running as a service on the PC, you will need to verify that the service is not running. You may need to re-register and stop the service.
  • TAC INET
  • 6452
