Main differences between Continuum v1.94 SP1 and Continuum v2.0
  • Main differences between Continuum v1.94 SP1 and Continuum v2.0
‎2018-09-06 09:25 AM
Last Updated: Crewman ContentModerator ‎2025-09-25 02:52 AM
What are the main differences between Continuum v1.94 SP1 and Continuum v2.0?
Andover Continuum
Continuum v2.0
Required a quick list of differences between the versions of Continuum to evaluate if a site upgrade to v2.0 was beneficial.
The main features that Continuum v2.0 has over v1.94 are listed below.
  • Microsoft Internet Explorer 10 32 bit support
  • SQL Server 2012
  •  Microsoft Internet Explorer 11 32 bit support
  • Software licensing Support. See Software Licensing for Continuum 2.0 and StruxureWare Solution.
  • Email SMTP Support. See SMTP Email Alarm Configuration in Continuum 2.0.
  • Extended Custom Wiegand Card* (ACX Series Only). See Extended Custom Wiegand features available for ACX57xx controller released in V2.0.
  • Support for new door attribute 'ValidAttempt' see New Door attribute 'Valid Attempt' added in Cyberstation 2.0 for more information.
You can also find more details in the v2.0 Feature Blast. And further information on Continuum v2.0 with the links in Continuum 2.0 Product Announcement, Feature Blast, Compatibility Matrix and Installation Guides.
  • 16982
