MSDE Not Installing on a Windows 2000 Professional PC
  • MSDE Not Installing on a Windows 2000 Professional PC
  • Roger_Bently
    Roger_Bently
‎2018-09-06 03:08 PM
  • It gets to 98% and then quits without installing anything
  • MSDE
  • Windows 2000 Professional
Microsoft network printer sharing settings are stopping the installation from completing.
  1. Open up My Network PlacesPrinter
  2. Go to Network and Dial up Connections
  3. Go to Local Area Connection
  4. Select the General Tab
  5. Uncheck the Files and Printer Sharing for Microsoft Networks
  6. Retry the install again.
  7. Once the software is installed, go back and check that box again so that Crystal Reports will run and print to a printer.
  • TAC INET
  • 1872
