MNB-1000 with firmware Revision 1.50E, Router Table Management Changes
  • MNB-1000 with firmware Revision 1.50E, Router Table Management Changes
  • RandyDavis
    RandyDavis
  • SESA113595
    SESA113595
‎2018-09-07 09:07 PM
Last Updated: Guinan RandyDavis Guinan ‎2023-03-23 06:35 AM
In MNB-1000 with firmware Revision 1.50E, the Router Table can be viewed and /or reset without resetting the Plant Controller. This allows users to clear table entries that could cause router problems, without needing to reset the MNB-1000.
TAC IA Series
  • I/A Series MNB-1000 (Plant Controller) with firmware Revision 1.50E, or later.
  • WorkPlace Tech Tool, Commissioning Tool (WPT CT) version 5.7.7 and later
Product enhancement.
To view or reset the Router Table, choose from the following procedures, depending on the version of firmware:
  1. For MNB-1000 with Revision 1.50E, use a web browser to access the Plant Controller to view or clear its Routing Table. Click here to see the Release Notes for Revision 1.50E, for more details.
  2. For MNB-1000 with Revision 1.510, use the WorkPlace Tech Tool Commissioning Tool, version 5.7.7.
Go to the Device Properties, Diagnostics Tab, and Router Table Information button. Click here to see the Release Notes for WPT 5.7.7, for further details.
  • TAC IA Series
Tags (2)
  • 4943
  • RandyDavis23
