MN300, MN350, MN550 and MN650 SLink Sensor Setpoint Resolution
  • MN300, MN350, MN550 and MN650 SLink Sensor Setpoint Resolution
  • Gary
    Gary
  • CraigEl
    CraigEl
  • DavidChild
    DavidChild
  • sesa119747
    sesa119747
‎2018-09-07 03:06 AM
Last Updated: Administrator CraigEl Administrator ‎2025-11-03 03:17 PM
  • The MN300 controller supports 0.1 unit resolution for setpoint adjustments when used with a SLink sensor.
  • The MN350, MN450, MN550, and MN650 controllers (firmware versions 2 and 3) only support 1.0 unit resolution.
Satchwell MicroNet
  • MN350
  • MN450
  • MN550
  • MN650
  • Satchwell MicroNet
Firmware versions 2 and 3 of the MN350–MN650 controllers do not support 0.1 unit resolution.
⚠️ Important Notices
  • The MicroNet 50 series controllers (MN350, MN450, MN550, MN650 LCD and Touchscreen) have been withdrawn from sale.
  • The IAC 420, IAC 600, and Touchscreen models have also been discontinued.
  • No direct replacements are currently offered.
For more details, refer to:
  • PA-00495 - Notice of Withdrawal - Satchwell Sigma (PDF)
  • PA-00528 - End of Commercialization - Satchwell Sigma (PDF)
Firmware Update
  • Firmware version 5 (released August 2008) for MicroNet 50 controllers supports 0.1 unit resolution when used with:
    • Updated SLink2.FCG file for VisiSat 2.1 Build 148
Slink2.FCG File for Micronet 50 Controllers Firmware v5.zip
Tags (3)
  • 3308
  • CraigEllis25
  • GaryMontague19
