MN-LCD Uploading – Best Practices
  • MN-LCD Uploading – Best Practices
  • CraigEl
    CraigEl
  • RyanSuar
    RyanSuar
‎2018-09-06 01:23 PM
Last Updated: Administrator CraigEl Administrator ‎2025-10-23 06:29 PM
Micronet LCDs may fail to upload configurations from MicroNet controllers correctly, leading to incomplete or missing display data.
Satchwell MicroNet
  • MicroNet LCD Displays
  • MicroNet Controllers
  • VisiSat Configuration Tool
The upload failure typically occurs when the LCD configuration is not properly transferred from the controller’s RAM to the LCD’s EEPROM. This can happen due to:
  • Power cycling or resetting the controller before LCD connection
  • Incorrect connection sequence
  • Locked configuration settings in VisiSat
Follow these steps to ensure successful upload and avoid data loss:
How the Upload Process Works
  1. Download to Controller: LCD configuration is first downloaded to the controller’s RAM.
  2. Transfer to LCD: When the LCD is connected, it detects the configuration file and transfers it to its EEPROM.
  3. RAM Clearance: After transfer, the controller’s RAM copy is deleted.
  4. Important: If the controller is powered off or reset before the LCD is connected, the configuration will be lost.
LCD Download Procedure
  1. Power On Controller: Ensure the controller is powered before starting.
  2. Download Configuration via VisiSat.
  3. For Standalone NCP Controllers:
    • Disconnect communications before connecting the LCD.
    • Ensure LCD comms links are properly fitted.
  4. For Networked NCP Controllers:
    • Install an MNN-COM card.
    • LCD must be remotely mounted.
  5. Connect LCD:
    • Keep controller power ON.
    • Apply power to the LCD.
    • Note: Do not press any keys during connection unless using firmware revision J or earlier.
  6. Wait for Configuration Load.
  7. Troubleshooting:
    • If upload fails, check that the controller’s “Configuration Locked” property is set to No in VisiSat.
  8. Final Step: Remove the protective strip from the LCD battery.
  • Satchwell MicroNet
Tags (2)
  • 6003
  • CraigEllis25
