Lua Program for DIM Digital Input modules
  • Lua Program for DIM Digital Input modules
‎2018-09-11 07:44 AM
Last Updated: Crewman ContentModerator ‎2025-08-11 03:56 AM
Require a Lua script for using DIM modules
SmartStruxure Lite
Using a Digital Input Module and Lua script is required to view the Inputs.
For Sontay's DIM4 module download the script here.
For Sontay's DIM6 module download the script here.
For AXIO's DIM module download the script here.
For a generic DIM module download the script here. The voltage received at the AI may need tuning.
Copy and paste the text into a Lua program and create the Binary Values (BV).
  • EcoStruxure Building Expert
  • 16622
