Lost Multi Purpose Manager (MPM) Password
  • Lost Multi Purpose Manager (MPM) Password
‎2018-09-11 02:55 PM
Last Updated: Crewman ContentModerator ‎2025-09-25 02:51 AM
Unable to gain access to Building Expert
EcoStruxure Building Expert
SmartStruxure Lite Multi Purpose Manager
  • MPM-GW
  • MPM-UN
  • MPM-VA
The admin password has been changed and the user has lost the password
For MPM with firmware 2.14 and earlier:
Send the MPM 'default.db' file to Product Support.
From a web browser, you can save the default.db file to the local drive by typing the address http://[ip_address]/root/default.db (replace [ip_address] with the actual IP address of the MPM, or 10.50.80.2 if bootloader is used)
For MPM with firmware 2.15 and later:
Send the MPM Node ID or MAC Address to Product Support.
Refer to the document StruxureWare Building Expert Password Recovery When Accessing MPM - Reference Guide for the procedure to obtain the MPM Node ID or MAC Address.
  • EcoStruxure Building Expert
Tags (4)
  • 16694
  • 16701
  • CraigEllis23
  • reset
100% helpful (2/2)
