LonWorks Device Not Discovered During Discovery Process
  • LonWorks Device Not Discovered During Discovery Process
  • PeterLarsen
    PeterLarsen
Spock PeterLarsen Spock
‎2025-10-21 04:54 PM
on ‎2025-10-21 04:54 PM
When upgrading a TAC Vista site to EcoStruxure Building Operation (EBO), LonWorks devices may not be discovered during the device discovery process in the AS-P.
Building Operation Automation Server Premium (AS-P).
This issue typically occurs when the original TAC Vista database was configured using a third-party network management tool such as LonMaker or NL220. These tools can assign a custom domain ID to the LonWorks network.
  • Default Domain ID in TAC Vista: 1/11
  • Default Domain ID in EBO: 1/254
If the domain ID used during the initial setup differs from EBO’s default, the AS-P will not detect devices on that domain.
  1. Identify the Current Domain ID
    • Use the existing TAC Vista database to determine the domain ID configured on the LonWorks devices.
    • Alternatively, use NodeUtil to identify the domain ID. Refer to the article: Finding LON devices under a different domain length with NodeUtil
  2. Configure a Spare AS-P
    • Set the domain ID on a spare AS-P to match the existing domain ID used in the site.
    • For guidance, see: How to locate and change the LonWorks domain ID
  3. Discover Devices
    • Use the spare AS-P (now configured with the matching domain ID) to perform device discovery.
    • The previously undetected devices should now appear and be accessible.
  4. Decommission Devices
    • In the AS-P, navigate to the Actions menu for each discovered device.
    • Select Decommission to revoke the device’s address and stop communication.
  5. Reintegrate Devices
    • After decommissioning, re-add the devices to the LonWorks network.
    • They should now be discoverable by an AS-P configured with the standard EBO domain ID (1/254).
Labels (2)
  • PeterLarsen25
