Links or binding paths In TGML graphics are changed after the graphic is edited
  • Links or binding paths In TGML graphics are changed after the graphic is edited
  • RandyDavis
    RandyDavis
  • PeterEdvik
    PeterEdvik
  • Jonas_Brissman
    Jonas_Brissman
Janeway Jonas_Brissman Janeway
‎2019-11-14 09:50 AM
Last Updated: Janeway PeterEdvik Janeway ‎2020-02-28 02:11 AM
A site is converted from TAC Vista to EcoStruxure Building Operation using TAC Vista Conversion Tool and all TGML graphics work fine.
After a TGML graphic is edited all links or binding paths in the graphic are changed.
Example:
Before
After
  • Building Operation Workstation
  • TAC Vista Conversion Tool version 2.X
This issue will only be seen in TGML graphics which originally have been OGC graphics in TAC Vista and then converted to TGML graphics at some point.
This issue is fixed in TAC Vista Conversion Tool version 3.02 and later.
Redo the conversion using a version of the TAC Vista Conversion Tool 3.02 or later.
Tags (2)
  • JonasBrissman19
  • JonasBrissman20
