License Features list for version 3.0 and 4.0 Product names
  • License Features list for version 3.0 and 4.0 Product names
  • RobertAndriolo
    RobertAndriolo
  • CraigEl
    CraigEl
Picard RobertAndriolo Picard
‎2022-06-08 08:57 PM
Is there a quick reference I can search to find out what features are included in a particular license
When manually adding my Product during offline embedded license workflow, how do I know which Features is included and in what quantity?
  • Building Operation EBO 2022 v4.03 and lower
  • Embedded Offline Licensing Offline Activation of Licenses Workflow
Currently, no information lists features for each Product name listed in the Part Number Summary for EBO 2022.  A documentation defect (QC 49762) has been raised, which should resolve this.  This article has been created to assist somewhat during this process while waiting for this to be corrected.  The recommendation, if possible, is to perform license activation online to avoid having to enter this detail.
Important Note:
This information is no longer valid for EBO 2022 (Maintenance Release 4.0.4) and EBO 2023 and greater.  The details below are still provided for reference only and are not needed for these later versions.
Attached are two documents that provide version 3.0 and 4.0 License details.  The documents contain all searchable details, including:
  • Product Name
  • Features
  • Part Numbers
Additional details required for Device Administrator "Feature Name" offline entry:
SpaceLogic Server license details
Feature Name
(seen in Device Admin)
License name
(seen in Features document)
Description / Comments
Automation Server server.as.base
SmartDrivers smartdriver.license
SNMP Notifications server.alarms.snmp
Personal Dashboard client.dashboard
TimescaleDB server.timescale
MQTT Publish/Subscribe server.mqtt.rw Enables EBO, as MQTT Client, to publish data on an MQTT Broker and to subscribe to the same data.
Serial Modbus server.modbus.rtu Allows SmartX server serial communication - Modbus RTU
Serial MS/TP server.bacnet.mstp Allows SmartX server serial communication - MSTP
ES Connection server.connect.to.es Allows SmartX server to be hosted by an Enterprise Server
Server I/O server.io Allows SmartX server to use IO
Field Devices server.device.as Allows SmartX server to host one field device
SAML Authentication server.as.auth.saml
Zoning client.zoning Enables use of zoning tools
BACnet IP server.bacnet.ip Allows SmartX Server to communicate using BACnet IP
Software Assurance software.assurance
Feature Name (Automatically included with bundle licenses)
  client.webstation Allows Webstation to log on to an AS
  server.cloud.customer Cloud connectivity - Checked by Cloud SMS (Production)
  server.as.scalable Included in the license that allows SpaceLogic servers upgrades. i.e. Standalone to Standard etc.
Example: Product Name: ASP-NL Bundle upgrade - Full to ASP Full
  1. Search the document for the product name in the attached document. In this case, the version 4 document.  Below is the result seen in the document:
  2. From this, the associated Features and Quantity are shown.
  3. In Device Administrator, then add the respective features and quantities when adding the product manually to the Entitlement. Use the above table to correlate between Feature Name and License Name.
    The example shown below:
Tags (5)
  • HernanUruena24
  • QC 49762
  • RobertAndriolo22
  • RobertAndriolo23
  • RobertAndriolo24
100% helpful (1/1)
