Legacy NPR 2000.
  • Legacy NPR 2000.
  • Roger_Bently
    Roger_Bently
Legacy NPR 2000.
‎2018-09-06 12:17 PM
Unable to communicate as lights are solid red on the front panel.
All versions of I/Net Software.
The lights indicate that there is no communication to the device which can be caused by the failure of the power supply. This has been a known issue as those devices are not manufactured anymore and needs to be replaced.
Replace the Legacy NPR 2000 with the Xenta 527-NPR.
  • TAC INET
  • 8042
