Large change in Database IDs
Select a Country
  • Large change in Database IDs
  • RobertAndriolo
    RobertAndriolo
  • AdamSteele
    AdamSteele
AdamSteele Champion
‎2019-02-17 08:28 PM
There are large jumps in Database ID numbers in the lists of objects in Security Expert. Most notably seen in the Trouble Inputs table.
In the below example the Database ID's in the Trouble Input table jumped from 420 to 1424.
Figure 1 - Database ID'sFigure 1 - Database ID's
EcoStruxure Security Expert
  • Security Expert Server
  • Security Expert Client
This is a rare occurrence but when seen can be due to the creation and deletion of Controllers and Expanders as a site is being configured or just normal operation as SQL maintains the Security Expert database.
No action required. This is a benign condition which does not affect the normal operation of Security Expert.
  • EcoStruxure Security Expert
Tags (3)
  • AdamSteele19
  • AdamSteele20
  • AdamSteele23
