Key Ring is Corrupt and Unrecoverable
  • Key Ring is Corrupt and Unrecoverable
  • JohnBoehmer
    JohnBoehmer
  • RandyDavis
    RandyDavis
Guinan RandyDavis Guinan
‎2020-03-09 02:00 PM
Niagara Runtime Environment (NRE) fails
Console output when starting Workbench
TAC IA Series
I/A Series N4 Workbench
An issue has occurred in the security of the user home for the installation of Niagara N4
If the Workbench fails to launch.
  1. Open the Console for the build you are trying to use by following the illustrated path and clicking the console.exeConsolePath.jpg
  2. If the Console output is as shown under "Issue" above, follow the path shown below. Complete the instructions in the illustration below.UserHomePath.jpg
  3. Open the Workbench as you normally would.
  • TAC IA Series
Tags (5)
  • console
  • n4
  • nre
  • RandyDavis20
  • RandyDavis22
