KYZ Pulse Output on a Power Meter
  • KYZ Pulse Output on a Power Meter
  • PeterEdvik
    PeterEdvik
  • sesa139513
    sesa139513
  • CraigEl
    CraigEl
‎2018-09-10 10:54 PM
A specification for a power meter states that it provides KYZ pulse outputs. What is a KYZ pulse output?
All Product Lines
Utility Meter with KYZ pulse outputs
Some meter specification sheets may state that the device outputs KYZ pulses.
KYZ is a designation given to a relay used to create pulses for electrical metering applications. It is commonly a Form C relay (SPDT). The term KYZ refers to the contact designations: K for common, Y for Normally Open, and Z for Normally Closed.
Labels (7)
  • Satchwell BAS & Sigma
  • Satchwell MicroNet
  • TAC IA Series
  • TAC INET
Tags (2)
  • 11662
  • PeterEdvik20
50% helpful (1/2)
