It is not possible to query multiple OU containers with the Personnel Import Utility
  • It is not possible to query multiple OU containers with the Personnel Import Utility
  • AdamSteele
    AdamSteele
‎2018-09-06 08:38 AM
With the Personnel Import Utility, is it possible to query multiple OU containers?
Andover Continuum
Personnel Import Utility (PIU)
Need to be able to query multiple OU containers. Similar to below query.
Server Name:  LDAP://test/DC=test, DC=com
(test and com are separate domains)
Unfortunately the query cannot be changed to accommodate this. Different Domains can be specified but it is not possible to go down to the OU level.
  • 18734
