PCT2 Error: System.InvalidOperationException: Failed to run: Import-Vm -Path
  • PCT2 Error: System.InvalidOperationException: Failed to run: Import-Vm -Path
  • Jonas_Brissman
    Jonas_Brissman
  • StephenYang
    StephenYang
Janeway Jonas_Brissman Janeway
‎2024-11-19 06:24 AM
Last Updated: Admiral StephenYang Admiral ‎2024-12-06 01:03 PM
Getting error "Failed to run: import-VM" when trying to install PCTv2
Building Operation Project Configuration Tool (PCT)
Could install PCTv2 fine but the issue started when going back and forward between PCTv1 and PCTv2 so that might have caused the issue.
  1. Uninstall Hyper V in Windows Programs and Features and restart computer
  2. Delete everything in ProgramData\Microsoft\Windows\HyperV
  3. Install PCTv2 version 2.0.2.13 or later
Labels (2)
  • Project Configuration Tool
Tags (2)
  • JonasBrissman24
  • StephenYang24
50% helpful (2/4)
