Is trend logs stored in the SQL server or Vista database?
  • Is trend logs stored in the SQL server or Vista database?
  • Jonas_Brissman
    Jonas_Brissman
‎2018-09-06 10:48 AM
Is trend logs saved in the SQL server or Vista database?
TAC vista 4.3.0 and later versions.
All trend log values are sent from the Vista server to the $queue folder in the Vista database and then a service called TAC DSSwriter is taking the trend log from the $queue folder and transfer them in to the SQL database.
All trend logs and events are stored in a SQL database.
  • 12042
