Is there any way to mass change any of the bCX / ACX / NC2 settings as configured from the controllers configuration webpage?
  • Is there any way to mass change any of the bCX / ACX / NC2 settings as configured from the controllers configuration webpage?
  • AdamSteele
    AdamSteele
‎2018-09-06 08:40 AM
ACX57x0
CX9680
bCX9640
bCX4040
CX9702
Settings need to be changed en-mass for a large number of Controllers. In one particular case there were a large number of ACX57xx’s that needed to have the first and second SNMP alarm target PC's IP addresses changed for all controllers.
There is no way to set all of these at once. As with all of the settings on the controller configuration webpage, they will need to be manually changed one at a time by connecting to each individual controllers configuration webpage.
  • 18483
