Is the b4920 still available for new purchase and is it still supported?
  • Is the b4920 still available for new purchase and is it still supported?
  • BillNeville
    BillNeville
‎2018-09-06 01:14 PM
b4920
Yes, the b4920 is still available as of this article publication (October 2011).
However, the same functionality can be obtained less expensively by purchasing a bCX1 with 127 node support AND a b3920. In addition you get the added reliability of distributing the combined functionality across two different devices. If a b4920 goes down you lose control of your on-board IO and communication to your Infinet or MS/TP bus. If you lose one of two devices the other will continue to operate.
On the other hand, the b4920 takes up less physical space than the two devices.
  • 6274
