Is it possible to use an Automation Server as a LON Device in an OpenLNS Database.
  • Is it possible to use an Automation Server as a LON Device in an OpenLNS Database.
  • Jonas_Brissman
    Jonas_Brissman
  • sesa177673
    sesa177673
‎2018-09-11 06:28 AM
Last Updated: Janeway Jonas_Brissman Janeway ‎2023-04-13 04:51 AM
If an Automation Server should be used as a LON Device in an OpenLNS Database using the OpenLNS Commissioning Tool? Is that possible to do?
Automation Server 1.4.1.68 or newer
Some sites may wish to use other Lonworks configuration tools than EcoStruxure Building Operation Workstation.
This is possible in 1.4.1.68 and newer. Add a Lonworks Local FT-10 interface and then add an Externally Managed Lonworks Network.
Tags (2)
  • 15195
  • JonasBrissman23
0% helpful (0/1)
