Is it possible to run TAC Vista 5.X.X in Windows XP compatibility mode (When TAC Vista Installed on Windows Vista, Windows 7, Server 2003/2008)
  • Is it possible to run TAC Vista 5.X.X in Windows XP compatibility mode (When TAC Vista Installed on Windows Vista, Windows 7,...
  • CraigEl
    CraigEl
  • Sampath_Konda
    Sampath_Konda
‎2018-09-06 01:27 PM
Last Updated: Administrator CraigEl Administrator ‎2022-08-08 09:53 PM
TAC Vista
  • TAC Vista 5.X.X
  • Windows XP
  • Windows Vista
  • Windows 7
  • Windows Server 2003/2008
If TAC Vista 5.x.x is Installed on Windows 7, Windows Vista, or Windows Server 2003/2008, is it possible to run the Vista Workstation on Windows XP using Compatibility mode.
TAC Vista has several other applications that work together with Vista. These applications do not support compatibility mode.
  1. Upgrade to Vista 5.1.4 or later which support Windows 7.
  2. If the operating system is a 64-bit version, upgrade to Vista 5.1.5 or later.
For the compatibility matrix see Software and Firmware compatibility matrix for older versions of the traditional product lines.
  • 6119
100% helpful (1/1)
