Is it possible to let the ES directly write the "write to file notification" into the Windows event database?
  • Is it possible to let the ES directly write the "write to file notification" into the Windows event database?
  • SharlinaRe
    SharlinaRe
  • Jonas_Brissman
    Jonas_Brissman
‎2018-09-06 12:44 PM
Last Updated: Captain SharlinaRe Captain ‎2022-11-16 06:03 AM
Is it possible to let the ES directly write the write to file notification into the Windows event database?
Is there a rotation for the Write To File Notification file so that a new file is written when the file is bigger than xMB?
EcoStruxure Building Operation - ES
Write to file notification can only be written to a file in the "db / notifications" folder on the server where the notification object is located. Unfortunately there is no rotation either.
At this time it is not possible for an Enterprise Server to write directly to the Write to File notification in the Windows event database. There is also no rotation for the Write to File notification file so that a new file is written when the file is bigger than xMB.
Tags (2)
  • 7218
  • SharlinaRenwall22
