Is it possible to get a XIF from Lonmaker
  • Is it possible to get a XIF from Lonmaker
  • Benji
    Benji
  • CraigEl
    CraigEl
  • sesa150555
    sesa150555
‎2018-09-10 11:26 PM
Last Updated: Administrator CraigEl Administrator ‎2022-08-09 07:07 PM
Is it possible to get a XIF from Lonmaker when you have commissioned it by "upload" from device?
TAC Vista
  • TAC Vista Toolpack
  • TAC Vista Server
  • LonMaker
If you don't have the XIF you can upload from the device in Lonmaker.
There is no way to get the XIF from LonMaker but the system plug-in will create a new XIF when you add the device to the TAC Vista db. Refer to SNVTs, SCPTs, or Module Names are missing from Vista after device is added to database from System P... for instructions on how to locate the XIF generated by the system plugin.
  • 12301
