Is it possible to change the column size for the alarm window in Webstation?
  • Is it possible to change the column size for the alarm window in Webstation?
  • Jonas_Brissman
    Jonas_Brissman
‎2018-09-06 12:13 PM
Is it possible to change the column size for the alarm window in Webstation? For some alarms it is not possible to see the whole alarm text for an alarm in the alarm window, he need to click on details to see the alarm text.
TAC Vista Webstation 5.1.x
The size of the columns is decided when the Webpage is built up and this is nothing that is possible to change in the Websettings.
No this is not possible to change in the Websettings.
  • 8185
