Is it possible to access the value of a doors ADA output for programming or reporting via graphics, listviews or reports?
  • Is it possible to access the value of a doors ADA output for programming or reporting via graphics, listviews or reports?
  • JohnBoehmer
    JohnBoehmer
‎2018-09-06 09:34 AM
Is there a way to display the value of a doors ADA output or to use this value in a Plain English program?
ADA output
Door attributes
Need to display and track the value of a doors ADA output.
There is no sanctioned way to access or use the value of a doors ADA output.  While in some cases it may be possible to create a separate output object with the same channel number to track this value, this kind of configuration is known to have issues and it is not recommended.
  • 16225
