Is a Satchwell DWT0002 sensor fitted directly into the waterway, or into a pocket?
  • Is a Satchwell DWT0002 sensor fitted directly into the waterway, or into a pocket?
  • sesa139513
    sesa139513
  • sesa125819
    sesa125819
‎2018-09-11 08:25 AM
Is a Satchwell DWT0002 sensor fitted directly into the waterway?
DWT
0002
Sensor
Fast
Response
Customer has to replace this sensor and is not sure how to remove it.
The DWT0002 sensor provides a fast response to temperature changes, and is fitted directly into the pipework.
Important Note;
When changing this sensor, the water must be isolated and drained from this part of the system.
To review the data sheet, please click HERE.
  • Field Devices
  • 14723
