Is Vista OPC server supported on a 64-bit operating system?
  • Is Vista OPC server supported on a 64-bit operating system?
  • Jonas_Brissman
    Jonas_Brissman
‎2018-09-06 01:18 PM
  • TAC Vista 5.1.6
  • TAC Vista OPC server 1.1.6
  • 64-bit operating system
TAC Vista OPC server 1.1.6 is not officially supported on a 64-bit system
TAC Vista OPC server 1.1.6 is not officially supported on a 64-bit system, but it has been tested on a limited run and no problems have occurred. It is always better to stick with recommended and supported hardware, but in this exception, it may be okay.
  • 6167
