Is LDAP supported in EBO?
  • Is LDAP supported in EBO?
  • Mahmoud_Sayed
    Mahmoud_Sayed
Kirk Mahmoud_Sayed Kirk
‎2023-02-07 06:15 AM
on ‎2023-02-07 06:15 AM
As per RFC 4510 The Lightweight Directory Access Protocol (LDAP) is an Internet protocol for accessing distributed directory services that act in accordance with X.500 data and service models. Do EBO servers support LDAP protocol?
  • Building Operation Enterprise Central
  • Building Operation Automation Server Premium
  • Building Operation Automation Server Bundled
  • Building Operation Edge Server - Standard
Need to know if EBO supports LDAP protocol.
EBO doesn't support LDAP protocol. EcoStruxure Windows based BMS servers (Enterprise Server/ Enterprise Central) support integerationto Windows Active directory. The Active Directory integration is not using LDAP directly, but the NetLogon service on the Windows OS that ES/EC is running on.  This connection enables inherited user account groups from the Windows Active Directory to EcoStruxure Building Operation software, and allows users to log on to WorkStation with their Windows user accounts. Refer to: Windows Active Directory User Groups and Integrating Windows Active Directory user accounts with EcoStruxure - Communities
For EBO 2022 or higher, Authentication using SAML 2.0 is also supported (Edge Server, AS-P, AS-B, ES and EC) . This enables configuring WebStation to use single sign on (SSO) using Federated Authentication, refer to: Federated Authentication. SAML Authentication feature requires license.
  • MahmoudSayed23
