Invalid user name or password when creating a Continuum database on SQL Express
  • Invalid user name or password when creating a Continuum database on SQL Express
  • Alan_Wood
    Alan_Wood
‎2018-09-06 11:01 AM
Last Updated: Administrator DavidFisher Administrator ‎2019-09-04 08:03 AM
When creating a new database an error pops up that indicates that the Windows login name or password is invalid.
Andover Continuum
  • Continuum
  • Windows XP
  • Windows Vista
  • Windows 7
  • Windows Server 2003
  • Windows Server 2008
There is already a Continuum database created.
Permissions for the Windows user are not allowing the database creation.
  1. Check to see if there are Continuumdev and ContinuumLog files in the folder. (Look for the folder path in database initialization)
  2. Use My Computer to navigate to that folder and see if the files already exist. If they do, copy them if needed and then delete them.
  3. Try the database creation again after that.
  4. The Windows user may not have the appropriate permissions as an admin
  5. Create a new local admin user and then login using the new login
  6. Try the database creation
  • 11369
