Invalid Page fault in mfc42.dll or error 429 for I/NET 2000 users
  • Invalid Page fault in mfc42.dll or error 429 for I/NET 2000 users
  • sesa139513
    sesa139513
  • Roger_Bently
    Roger_Bently
‎2018-09-06 03:10 PM
I/NET 2000
 The following steps will get this fixed really quickly:
  1. Go to the “Start” Button on the task bar at the bottom.
  2. Choose the “Run” Button.
  3. Type in REGEDIT, then hit Enter.
  4. Make sure that I/Net and I/O Server is not running.
  5. GO to HKEY_Current User.
  6. Scroll down to the “Software Tab”.
  7. Select the file folder “CSI-Control System International”.
  8. Select the “I/Net W” file folder.
  9. Select the “toolbars” file folder.
  10. Delete all the Tool Bar entries.
  11. Re-boot the PC, this will rebuild the new toolbars in the registry listing.
  12. Start I/NET again and you should be able to log on now.
  • TAC INET
  • 1824
