Interface SE3020W1045 to SE7600H5045B and access via BACnet
  • Interface SE3020W1045 to SE7600H5045B and access via BACnet
  • Leo_Tantalo
    Leo_Tantalo
‎2018-09-06 09:21 AM
Can the remote sensor with override switch (SE3020W1045) be interfaced to a SE7600H5045B and be accessed via a BACnet integration? The override switch is a trigger to provide cooling to the area served.
EcoStruxure Building Expert
SmartStruxure Lite
Provide end user a simple way to get comfort cooling
Interface the override switch to DI 01 on the SE7600H5045B. It will then be accessible via BACnet to trigger comfort cooling.
  • EcoStruxure Building Expert
  • 16978
